![]() | Home > Technical > Replacing Main Engine Wiring Loom L320 2006 range rover spor |
Are you driving it ?
Nveeate Member Since: 10 Aug 2021 Location: Scotland Posts: 28 ![]() ![]() ![]() |
Have you tried an automotive electrician? They may be able to just replace the damaged sections... |
Simon_CSK Member Since: 21 Dec 2020 Location: East Ayrshire Posts: 70 ![]() ![]() ![]() |
I am in the process of finishing that on an Insurance write off that I bought in September.
Lucksranout Member Since: 20 Jan 2022 Location: Devon Posts: 3 ![]() ![]() |
Hi thanks you all for your reply's, as it's a non runner andy, I'm currently awaiting it's recovery tomorrow, so when it arrives back from the garage from the initial diagnostics I will take some pictures of where it is burnt.
The first thing I need to know is the extent of the loom being replaced.
Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 315 ![]() ![]() ![]() |
As a former auto electrician from what you’ve described I can imagine the damage to be very localised so I would of thought a repair would be possible or if the damaged section is a spur cut it from a second hand loom and slice it in. Steve
I think you need more than a wiring loom |
It is more or less back together. Current cars
Holy c😬😬p!! That’ll be a new loom, at times like this I’m glade I only have six cylinders 😁 Steve
New Loom
