![]() | Home > General (L494) > Auxillary Battery replacement L494, Auto Stop Start battery |
pjbracer1 Member Since: 25 Aug 2014 Location: Southampton Posts: 409 ![]() ![]() |
Li of LiPO batteries are a great idea as they pack alot of punc however they are also quite volatile, so you would have to be careful with reagrd to charging as they often need to be discharged to around 20%, also if not maintained with a proper intelligent charger the battery could be a potential fire hazard ( Iguess if it was kept inside like a lipo container then that would solve that issue, but not sure about car insurance if there was a fire.
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 872 ![]() ![]() |
First time I have pulled the cover off to have a look at 2nd Battery. Was well pleased to find a large 2nd battery. No idea what the rating is but am assuming around 50 amp hrs judging by size. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Thinking of using this as my second battery, reckon I can squeeze it in. Will have the 12v connector wired direct so that I can run a fridge , fridge draw should be around 2 amps when cold.
Wiring direct should be fine as the car doesnt need this battery to be fair its there to assist the main one during stop starts, it will be tight getting that in there though, I thought that one was tight to get the cables on but you might need to get some cable extenders.
OK I have another question, can I replace the big starting battery with a Lipo4 battery. My battery is 5.5 years old and I am thinking replace both so both batteries have a similar chemistry. Seems the question is will the smart charge system charge a Lipo4 battery?/
Good question and the honest answer is I'm not sure, Lipo charged differently and so not sure how the BMS would would react or if it would charger properly.
Woody Woodpecker Member Since: 18 May 2016 Location: Wakefield Posts: 3 ![]() ![]() ![]() |
Brilliant write up thanks. |
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 263 ![]() ![]() |
I just changed my auxiliary battery as the stop/start light would not go out. Battery voltage was around 10.5 even after a run.
no probs chap the main batt is under the floor and will be the cause of most pains! EK950 is oem brand.
