![]() | Home > General (L494) > Auxillary Battery replacement L494, Auto Stop Start battery |
pjbracer1 Member Since: 25 Aug 2014 Location: Southampton Posts: 409 ![]() ![]() |
Hi guys I ve been getting the low battery waring on my car of late and I know im doing some short trips but reckon the little battery in the back is probably old so thought I'd give it a go seeing as its winter too!
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261 ![]() ![]() ![]() |
Just a reminder, the L494's from about 2017 on have a capacitor in that position which replaces the secondary battery, so if you look there and their is no battery then you have one with the capacitor.
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 260 ![]() ![]() |
I read your guide with interest. If only the writers of technical manuals could write in the same basic English as you do. Particularly the writers of IT related instructions. Its a particular bugbear of mine that in even basic guides, jargon is used constantly and items are described by acronym rather than spelling it out at least the first time the acronym is used. Even basic things like my central heating timer settings are a nightmare. Most of us are not car mechanics but with some common sense and plain English instructions including photos, then many similar tasks like the one you described can be accomplished.
Cheers mate Im in IT and know exactly what you mean, Id like to think I can turn my hand to most things technical but sometimes its just isnt easy when the person writing the instructions is generally too close to project and leaves out steps, Ive even worked with Microsoft to get some of their own instructions changed when they missed out some vital steps!
Laurie100uk Member Since: 01 Nov 2020 Location: Bristol Posts: 37 ![]() ![]() |
My start/stop in my 2016 HSE hasnt worked once since I bought the car about 5 months ago, do you think this is what I need to do to get it working again? And yes I'm sure its turned on |
So a quick updte on this! After chagning the aux battery and doing as i have i stopped getting the low batt warning but start stop only worked after i had fully charged the main battery!
dazzerboy Member Since: 18 Sep 2009 Location: staffordshire Posts: 212 ![]() ![]() ![]() |
How hard was it to change battery and which battery did you buy my stop and start now works since changing the small battery but may aswell change main battery as my vehicle is 5 years old and its got a lot of electrics relying on it lol
Just writing it up now mate and ill post the instructions, its not that hard take out spare wheel, losen the air compressor 2 bolts and it swings out of the way. then lift out some sound baffling foam stuff and you can see the battery in a tub, losen of the temrinals 10mm socket lift out and then put the new one in, I have a few tips that I found whilsts I was doing it so ill stick em in the write up. If a jobs worth doing, get a someone who knows what they are doing to do it!
Hi Mate whats the function called on the iid tool to reset the battery do you know |
Go into the service menu and its the battery reset function
Cheers mate havnt got that far yet with my iid tool |
L494 Main Battery Replacement
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 913 ![]() ![]() |
Good write up. I changed my batteries a while back & this is what I did to prevent re-setting any thing or using a Gap tool.
