![]() | Home > My Range Rover Sport > Project HST |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
First picture in the post shows it with a HSE badge on it not HST it now has, so probably dealer version.
J4XHY Member Since: 14 Feb 2021 Location: South Wales Posts: 20 ![]() ![]() ![]() |
Hi, by standard looking I mean no aftermarket bodykit etc added bits that come on later models . but I see what you mean👌 Update soon with non standard parts to modernise interior lol Numberplate - do you mean the shape? Not sure what that's got to do with ocd tho just personal preference? Last edited by J4XHY on Mon Jan 10 2022 10:25am. Edited 2 times in total |
Hi is this common as I haven't read much about it? Timing belts been done on it. I'll definitely look into it thanks |
The advert I've bought from says HST version. Checked logbook and its says HSE. I've also read about a stormer version, how do you know which one it would be? It's 2.7 tdv6 with Brembo brakes, Ace, HST kit but hasn't got the rear diff lock tho |
If it says HSE in the log book then the body kit was fitted after it left the factory, either by a dealer or someone else. I may be wrong but I belive the 2.7 was originaly called a Stormer, the TDV8 3.6 was called the HST.
Ok so haven't updated for a while..
Had some marks / scratches on the leather so decided to refurb myself
Lynchy Member Since: 24 Oct 2021 Location: Newcastle Posts: 80 ![]() ![]() ![]() |
Very nice job your doing here mate. What did you use to refurb the leather. Looks immaculate |
Usually just after belt change is when the risk is highest Info on differences http://www.disco3.co.uk/gallery/albums/use...sioner.pdf Guide is outdated, but first 2 pictures good for reference |
That's definitely a job that should be done during belt change then.. Looks a lot of work to do now 🙈 Timing belt done by previous owner by LR specialist.. I'll check receipt to see if done or maybe call them 👍 |
Thanks buddy 👍 she'd only done 55k when I bought her last year (59k now) so seats wasn't bad anyway. I bought scuffmaster leather dye (mixed to correct colour) - I posted them my headrest to get a perfect match. Some leather filler to fill any scratches. Then applied the dye using a airbrush gun on a air compressor. The gun only cost around £25. Dye another £25 and filler around £10. They really do look brand new 👍👍 Just done a set of 192k Range Rover Vougue seats and they look great ![]() |
Thanks for the info Col, appreciate it |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9049 ![]() ![]() ![]() |
It was just the letter spacing - it's an OCD thing for me as I'm not a fan. And the police aren't either, it should be noted. ![]() 2008 TDV8 - it was a labour of love and is much missed |
