Home > My Range Rover Sport > Project HST
First picture in the post shows it with a HSE badge on it not HST it now has, so probably dealer version.
Post #620733 Sun Jan 09 2022 7:55pm
J4XHY
United Kingdom 2007 Range Rover Sport TDV6 HST Java Black
Hightimo wrote:
Was the halo upgrade a kit you fit to the original lamp ?
Hi, yes you open original headlight to fit rings inside πŸ‘
Post #620743 Mon Jan 10 2022 9:16am
J4XHY
RRSTDV8 wrote:
J4XHY wrote:
Cheers Ash, defoπŸ‘ Want to keep it original looking but I think the small changes have made it look newer.
Changes stuff to make it non-standard and then says "want to keep it original". Sorry, got to laugh. Rolling with laughter Thumbs Up
Does your OCD extend to the number plate? Definitely looks wrong to me... Whistle Rolling with laughter
Is it a factory HST or a dealer one? The factory ones come with the locking rear differential.
Hi, by standard looking I mean no aftermarket bodykit etc added bits that come on later models . but I see what you meanπŸ‘Œ Update soon with non standard parts to modernise interior lol
Numberplate - do you mean the shape? Not sure what that's got to do with ocd tho just personal preference?
Post #620744 Mon Jan 10 2022 9:21am
J4XHY
Andy K wrote:
Make sure you change your oil pump as it’s a 2007 and they are very prone to failure
Hi is this common as I haven't read much about it? Timing belts been done on it. I'll definitely look into it thanks
Post #620745 Mon Jan 10 2022 9:22am
J4XHY
The advert I've bought from says HST version. Checked logbook and its says HSE. I've also read about a stormer version, how do you know which one it would be?
It's 2.7 tdv6 with Brembo brakes, Ace, HST kit but hasn't got the rear diff lock tho
Post #620746 Mon Jan 10 2022 9:28am
If it says HSE in the log book then the body kit was fitted after it left the factory, either by a dealer or someone else. I may be wrong but I belive the 2.7 was originaly called a Stormer, the TDV8 3.6 was called the HST.
Post #620749 Mon Jan 10 2022 9:43am
J4XHY
Ok so haven't updated for a while..
New rear calipers, brembo pads & disks, brake hoses, handbrake shoes, springs clips, bolts etc and gave them a paint. (also painted metal part of airbags satin black after photo was taken)
Repainted front calipers with new brembo decals. New brake fluid. Wire brushed chassis etc and repainted. Ace pipe pipes sanded to remove flaking paint and repainted. New ace pipe rubbers and brackets.
Set of 22" diamond cut stormers
Post #620752 Mon Jan 10 2022 10:03am
J4XHY
Had some marks / scratches on the leather so decided to refurb myself
Post #620754 Mon Jan 10 2022 10:19am
Lynchy
United Kingdom 2007 Range Rover Sport Supercharged HST Java Black
Very nice job your doing here mate. What did you use to refurb the leather. Looks immaculate
Post #620762 Mon Jan 10 2022 5:51pm
Usually just after belt change is when the risk is highest
Info on differences
http://www.disco3.co.uk/gallery/albums/use...sioner.pdf
Guide is outdated, but first 2 pictures good for reference
Post #620768 Mon Jan 10 2022 6:21pm
J4XHY
That's definitely a job that should be done during belt change then.. Looks a lot of work to do now πŸ™ˆ Timing belt done by previous owner by LR specialist.. I'll check receipt to see if done or maybe call them πŸ‘
Post #620801 Mon Jan 10 2022 10:49pm
J4XHY
Thanks buddy πŸ‘ she'd only done 55k when I bought her last year (59k now) so seats wasn't bad anyway.
I bought scuffmaster leather dye (mixed to correct colour) - I posted them my headrest to get a perfect match. Some leather filler to fill any scratches. Then applied the dye using a airbrush gun on a air compressor.
The gun only cost around Β£25. Dye another Β£25 and filler around Β£10. They really do look brand new πŸ‘πŸ‘
Just done a set of 192k Range Rover Vougue seats and they look great
Post #620803 Mon Jan 10 2022 10:56pm
J4XHY
Thanks for the info Col, appreciate it
Post #620804 Mon Jan 10 2022 10:58pm
It was just the letter spacing - it's an OCD thing for me as I'm not a fan. And the police aren't either, it should be noted. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #620807 Mon Jan 10 2022 11:52pm
