Home > Maintenance & Modifications > I need help: LED bar Fitted with HighBeams
deceunincke
Belgium 2008 Range Rover Sport TDV8 HSE Bourneville
I haven’t connected the wire yet with my highbeam. Had no time yet to do it.
And yes, i bought the osram Wire harness, it is too short though to get the wire inside the dashboard but that’s nit a problem when i will connect it with the highbeam.
Regarding the cooling; it is a really slim model and not that big; there is sufficient place for cooling to be done.
Post #620748 Mon Jan 10 2022 10:34am
Dave-t
jases4x4 wrote:
Dave, Do you think the light bar would cause an issue to the cooler? I didnt think it would restrict any air flow tbh theres alot of space at both sides of the light?
Someone mentioned a bigger one, I would just be careful on blocking it too much Joined the X5 45e club
1994 Defender 90 300 tdi
Post #620750 Mon Jan 10 2022 10:45am
jases4x4
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Santorini Black
I thought the same with the cooling, how did you attach the brackets facing down or upwards into the bumper? Think i will hav eto take the bumper off to access it aswell been an autobiography front bumper.
Post #620751 Mon Jan 10 2022 10:47am
deceunincke
I attached it down. Used the feet like mounting bracket’s and not the curved one’s.
A bit fiddling at beginning but it’s alright.
Take the “mouth” and look for the center. Then mark out where the lightbar comes with the feet. Use a pencil to mark the feet’s holes.
Drill the 2 holes, I manually drilled holes with a screw and then went on with bigger screws to make hole bigger because not really reachable when bumper is on car.
After 2 holes are made testfit the lightbar. Remove bracket and screw in brackets in holes. Use a spanner to hold nut (there’s a rubber like fin that you can push down to to feel the nut. Make sure u don’t drop nut.
Now get wireloom and run everything. Connect wireloom with lightbar; you’ll have the lightbar inside the “mouth”, make sure you don’t drop it.
Tighten everything down (mounting bracket’s) and take the lightbar and mount it on the brackets.
Post #620753 Mon Jan 10 2022 11:10am
jases4x4
Thats great help mate cheers. If you get time can you take a picture at night with the lightbar on and off it would be good to see how it performs low down as opposed to on the roof like alot have them. I might stick to just one in bumper like yourself if it’s sufficient.
Post #620755 Mon Jan 10 2022 11:39am
deceunincke
Lowbeam
https://www.rrsport.co.uk/gallery/albums/u...owbeam.jpg
Post #620780 Mon Jan 10 2022 9:09pm
deceunincke
HighBeam
https://www.rrsport.co.uk/gallery/albums/u...ghbeam.jpg
Post #620781 Mon Jan 10 2022 9:10pm
deceunincke
HighBeam + LED
Post #620782 Mon Jan 10 2022 9:11pm
deceunincke
LED
Post #620783 Mon Jan 10 2022 9:12pm
deceunincke
The LED does not have a wide range, but it shines so far away, it's crazy.
Here in Belgium i prefer to have a narrow'er and further light than a wide beam. We don't have a lot of forests so no need to light my side view that much.
Gives me over 200m of light.
That farm house was about 100meters away.
I could change the angle to either shine more down or more up. It's kinda the angle of my highbeams now.
Post #620784 Mon Jan 10 2022 9:14pm
jases4x4
Yes i saw it was a spot bar although osram have the new cb1000 thats spot and flood but this does the trick and goes far, i think you could angle it up alittle more for further distance but thats far really, photos are great 👍
Post #620790 Mon Jan 10 2022 10:20pm
deceunincke
That osram vx1000 cb looks nice! Is double the size of mine.
I guess it won’t fit in the “mouth” of the rrs though.
This would have to be mounted on a roof rack, wich I don’t have.
Post #620798 Mon Jan 10 2022 11:30pm
deceunincke
My osram vx500 should shine up to 415m far
Post #620802 Mon Jan 10 2022 11:50pm
jases4x4
Yes i saw the range which is pretty awesome for the size of it, I would like to get this one in the bumper and the vx1000 on the roof bars somehow around my new wind fairing. Its all money and time though mate 👍
Post #620806 Tue Jan 11 2022 12:49am
jases4x4
Looking to buy this in the next few days and put it in the mouth of the bumper the same, Do you think i could have it come on with Dipped beam and not blind oncoming traffic? Reason been the dipped lights i dont find them to lighten up the road enough for my liking?
Post #624437 Sun May 22 2022 4:05pm
