Home > General (L494) > Rear caliper motor cover cracked?
jamesgarbett
Garage has reported this as something to keep an eye on
Assume it's part of the electronic handbrake?
Would LR cover it under AUC warranty?
Post #618652 Tue Nov 02 2021 9:15pm
kas982
United Kingdom 2005 Range Rover Sport Supercharged Bonatti Grey
hmm...those dont normally "crack" on their own, so probably will be put down to damage, damage is not covered. no one can really say for sure without seeing it. ( assume you mean this part )
Post #618694 Wed Nov 03 2021 1:17pm
3hcp
I’m no expert, see my brakes seized on post.
Just sent my rear callipers for refurb they said seizing causes actuators to crack under load. Having said that they are only £60 on eBay. 2015 RRS DIESEL HYBRID
Post #620705 Sun Jan 09 2022 11:58am
Coedlan
Mine was cracked on one side where surface corrosion of the aluminium caliper had expanded the collar the plastic epb fits over, thus effectively bursting it apart. If I had spotted it within the warranty period, I would’ve expected it to be a valid claim, as it is my car is now 6 years old. Still works ok, but it’s days are numbered…….. 2016 L494 HSE
Post #620721 Sun Jan 09 2022 4:00pm
knwatkins
These parts do crack. See below. Same part on the L405 as L494...
https://www.fullfatrr.com/forum/topic57937-15.html
I would just replace now and not leave it. Kev
Post #620847 Tue Jan 11 2022 8:58pm
