![]() | Home > General (L494) > Rear caliper motor cover cracked? |
kas982 Member Since: 03 Oct 2021 Location: west mids Posts: 53 ![]() ![]() ![]() |
hmm...those dont normally "crack" on their own, so probably will be put down to damage, damage is not covered. no one can really say for sure without seeing it. ( assume you mean this part )
3hcp Member Since: 04 Nov 2021 Location: Devon Posts: 79 ![]() ![]() |
I’m no expert, see my brakes seized on post.
Coedlan Member Since: 30 Sep 2016 Location: N. Wales Posts: 71 ![]() ![]() |
Mine was cracked on one side where surface corrosion of the aluminium caliper had expanded the collar the plastic epb fits over, thus effectively bursting it apart. If I had spotted it within the warranty period, I would’ve expected it to be a valid claim, as it is my car is now 6 years old. Still works ok, but it’s days are numbered…….. 2016 L494 HSE |
These parts do crack. See below. Same part on the L405 as L494...
