Home > Faults & Fixes > Air flow meter 5l SC help |
Ken 153 Member Since: 02 Sep 2021 Location: Sheffield Posts: 188 |
Anyone? |
Mon Nov 29 2021 6:01pm |
MAFS534-OE anyone confirm that this is the correct part number? Also are they the same on both intakes as they "look" different.
Tue Dec 28 2021 5:43pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4992 |
They are both the same, just screwed in a different position. Rimmer Brothers have some cheap Chinese Specials at 80.00 quid each, special being they probably last as long as it takes to remove them from the box.
Tue Dec 28 2021 8:49pm |
Thanks Col. |
Tue Dec 28 2021 9:51pm |
Which is the best to go for??? |
Tue Dec 28 2021 9:53pm |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1172 |
You'll probably find that the LR and FoMoCo ones are just re-branded Denso.
Wed Dec 29 2021 6:15am |
Go for the Denso ones £120.00 each, same thing in a pretty L/R branded box will cost you £240.00.
Wed Dec 29 2021 7:11am |
Thanks guys, got a pair @ £117.50 each. |
Wed Dec 29 2021 12:56pm |
These arrived today, 5 minutes to fit them, ran the GAP to clear all faults, then took her for a test drive.
Thu Jan 06 2022 6:11pm |
