Home > General (L494) > L494 brake bleeding
Coedlan
L494 brake bleeding
I had bad corrosion to both rear brake lines (6 years old) thanks Tyrefitter for your 2019 post concerning these. Seems like they are a well known weak point on these cars. Your photos helped me confirm with my motor factor the correct parts needed. Amazing how the main lines that these connect to are like new in comparison. Definitely something for owners to look at before the end of 3 years warranty.
Is there any special procedure for bleeding the brakes on the L494?
As I’ve replaced the rear brake lines and using clamps, minimised the loss of fluid, I had to bleed just the rear calipers (I assume the fronts will be OK, as I didn’t disconnect the brake lines). I tried using a Gunson Eazibleed where 20psi is applied to the reservoir, but very little came out af the bleed nipples. I should say I didn’t try the traditional two man way pumping the pedal. I’ve read that there is a specific LR procedure, maybe involving having the engine running, etc. Has anybody got hands on experience of L494 brake bleeding? 2016 L494 HSE
Post #620368 Fri Dec 31 2021 4:33pm
Red Arrow
I done the same job recently and just gravity bled them Thumbs Up
Post #620369 Fri Dec 31 2021 4:50pm
Coedlan
Red Arrow, how long did it take, per side for them to gravity bleed? 2016 L494 HSE
Post #620372 Fri Dec 31 2021 5:26pm
Red Arrow
Around 10 mins a side just let it flow out and pedal was mint Thumbs Up
Post #620376 Fri Dec 31 2021 6:37pm
Tyrefitter
I did the same way as Red Arrow,gravity bled them. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #620384 Sat Jan 01 2022 8:21am
Coedlan
Thanks for all the responses and advice, I should’ve left them bleeding for longer. Spent 10 minutes today bleeding them the traditional 2 man way, very small amount of air in one side and job done. So I had actually bled one side
Think I was surprised that using an eazibleed providing 20 psi to the reservoir, it didn’t bleed faster. Just had to check here that there wasn’t some technicality that meant it couldn’t be done traditionally.
Anyhow, back on the road now, thanks and a happy New Year all. 2016 L494 HSE
Post #620406 Sat Jan 01 2022 3:23pm
