![]() | Home > General (L494) > Gearbox Fault followed by clunk then Terrain Response Specia |
What codes are stored? |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1176 ![]() ![]() ![]() |
It is quite likely that his attempt to 'calibrate' the TCM resulted in corrupted/mismatched software versions between the gearbox and the ECU, so now the car doesn't know what's going on.
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 915 ![]() ![]() |
As above, find another garage who knows what they are doing. Someone will soon be on to point you in the right direction. I use Disco Mikey, maybe a bit far for you to go Range Rover Sport (gone): Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S: Range Rover Fifty P400e |
Candyroch Member Since: 23 Dec 2021 Location: Glasgow Posts: 6 ![]() ![]() |
Sadly I don’t know the code that was displayed and I don’t have an ID tool to check.
Dundee
I’ve asked a guy I know from a local garage if he can read the codes for me and I’ll get back to you. Can you let me know your working hours too please mate and all going well I’ll try get up to see you.
Hi everyone apologies for the delay but I had to resort to the AA to get the code.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5032 ![]() ![]() ![]() |
As suggested someone screwed up the calibration or calibrated the wrong Module, do as suggested and take it to someone who knows what they are doing i.e Disco Mikey.
Hi Col,
Hi guys I just wanted to ask if anybody had any other specialists they could recommend?
Keep pursuing DM, or you may expose yourself to more messing about. 2006 2.7 TDV6 HSE in Cairns Blue. |
