![]() | Home > General (L494) > Brake discs @ pads l494 2016 |
timhum Member Since: 06 Mar 2017 Location: Suffolk Posts: 389 ![]() ![]() |
I'm not sure that you are correct that the Brembo option gave bigger brakes. I bought an HSE in 2017 and investigated this option and to me it appears to only offer a red caliper branded Brembo. I checked through the specifications at the time and the brake discs were the same size as standard. I appreciate that this doesn't directly help you but it may be that the standard pads are what you want.
I’ve just thrown a full set of discs in scrap as I upgraded mine to these & they were a reasonable price.
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1192 ![]() ![]() ![]() |
Andy, what brand & spec did you go for?
SC247 Member Since: 15 Oct 2019 Location: Staffs Posts: 60 ![]() ![]() |
I purchased these I have the Brembo brakes and the front disc are bigger 380mm against 365mm I think
Kevin-t Member Since: 10 Sep 2019 Location: Sheffield Posts: 123 ![]() ![]() |
Link to purchase please ![]() ![]() ![]() Had drilled and grooved on my old disco 3 for years, they never made any difference to the braking, however No way near as much dust on the wheels. Will be looking for these on my sport when the time comes ![]() |
They look like the Britpart ones...
Coedlan Member Since: 30 Sep 2016 Location: N. Wales Posts: 71 ![]() ![]() |
In 2015, when I specced the car, on the front, the bigger red callipers Tyrefitter shows in his pics was an upgrade, think they were bigger diameter, 380mm discs. I have seen newer cars with what look size-wise to be the same, just not painted red. Maybe they standardised on these bigger front brakes after my16. 2016 L494 HSE |
I got the discs from a local indi LR specialist who got them from Britpart,,I also had Hawk ceramic low dust pad on the front which kept the wheels really clean. Andy.
Thanks, all for your responses - spoke with local motor factor who identified the correct disc and pad sizes via their systems. I also had bad corrosion to both rear brake lines (6 years old) thanks Tyrefitter for your 2019 post concerning these. Seems like they are a well known weak point on these cars. Your photos helped me confirm with my motor factor the correct parts needed. Amazing how the main lines that these connect to are like new in comparison. Definitely something for owners to look at from as early as 4 years old. ![]() |
You can get those brake pipes from Advanced factors,,site sponsors on the forum.LR quoted me at the time they noticed mine we’re corroded when it went in for service,,£140 per side plus fitting,I got both sides from AF for around £90 posted for both sides & took me around 40-50 minutes to fit them both. Andy.
Hi, Tyrefitter got the brake lines and fitted them today, in the end, not as bad a job as it appeared.
Hi Coedlan,,wax oil,Lanogaurd,copper grease or similar should be fine,I covered mine in copper grease after fitting. Andy.
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 263 ![]() ![]() |
Resurrecting an old thread, apologies.
3hcp Member Since: 04 Nov 2021 Location: Devon Posts: 79 ![]() ![]() |
Try autodoc.co.uk
