Home > General > Front sensors.
alfapat
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Front sensors.
Front sensors and rear are on according to GAPIID.Rears are working fine, My bumper is off on the front as they may have the sensors which aren't working, checking them out , all of them seem to be working . There are no fault codes. Could it be that the front sounder is not working and wherre is it positioned please .Cheers Pat
Post #620120 Sun Dec 19 2021 8:45pm
Disco_Mikey
Sounder is part of the IPC
If you have the indicator tick, key in ignition bong etc, the front sounder is fine, and your fault lies elsewhere
Post #620121 Sun Dec 19 2021 9:57pm
alfapat
Indicator tick as in each of the four sensors , then yes. Orange light on the on off button steady . I will check the ignition bong tomorrow , battery off for fitting air condenser at the moment.
. Thank you.
IPC being the control module?
Post #620146 Mon Dec 20 2021 5:16pm
indicators being traffic direction indicators (that bmw drivers don't use)
IPC Instrumentation Pack (dash or clocks)
Post #620149 Mon Dec 20 2021 6:48pm
alfapat
Hmm, not quite getting that. What has the indicators got to do with the parking sensors.
Is what you're saying Mikey is the instrument panel do checks and one them is a bong that sensors are ok?
Post #620157 Mon Dec 20 2021 11:25pm
I would hazard a guess he means the same sounder is used for the direction indicators etc. as the parking sensors, so if it is working with the indicators there is nothing wrong with the sounder.
Post #620159 Mon Dec 20 2021 11:34pm
alfapat
Hmm, not quite getting that. What has the indicators got to do with the parking sensors a dififferent sound I'm thinking..
Post #620161 Mon Dec 20 2021 11:37pm
Most sounds come out of the same speaker in the instruments.
Eg indicator tick Tok, front park sensor beep
If you have no front sounds the instruments are faulty.
If you do have front sounds then it’s related to park sensor module only. The fronts could be configured as not fitted.
Post #620165 Mon Dec 20 2021 11:55pm
alfapat
OK I will check that , I know the front and rears are configured to work as a pair just now but rears only beep.
there is maybe something missing in the ccf. I have missed.
Next job inlet manifold replacement , here we go . I will update as I find there are a lot of unfinished queries on here. Or a lot of queries unfinished.!
Post #620185 Tue Dec 21 2021 11:01pm
alfapat
OK, I have no bongs when I open the door , or when indicators a used or when the key is in the ignition, so can I assume that that would be the reason why I cant hear the parking sensors are not audible? Again no faults for parking sensors a dash button is lit and not flashing. I can see there are videos to take the instrument cluster out , but would the sounder be repairable.
Post #620541 Tue Jan 04 2022 2:57pm
Here are some links to various other dash problems.
May give some leads
https://www.rrsport.co.uk/forum/topic53896.html
Post #620861 Wed Jan 12 2022 5:53pm
alfapat
Thanks did a read, I have the cluster out know and some clown has been there already , white clips broken bar two and a botch soldering job has been done , probably without success , so will have look for a speaker to fit. I reckon the rear one bight be the same kind. Anyway will have to determine if it is broken first.
Post #620999 Sun Jan 16 2022 6:03pm
alfapat
Cluster off , speaker resoldered! Job done well not quite .
Due the fact that there were no screws holding the INS Clust. I am haveng trouble identifying them . All I can tell thet are dome headed T30 Torx with a course thread , Has anyone got access to a parts list.Please.
Post #621045 Mon Jan 17 2022 9:55pm
Are you referring to the two at the bottom of the cluster ? if so they are 6mm by 20mm long.
Post #621048 Mon Jan 17 2022 10:48pm
alfapat
YES , I am , the thread pitch is not normal , though, a lot course than 1.0 pitch . I may have to find L/R parts store , I robbed one off a lower part which was the same , but then realised there were another two of the same missing also..But yes they are the ones.
Post #621049 Mon Jan 17 2022 11:24pm
