![]() | Home > In Car Electronics > All sounds gone and left hand steering buttons not working. |
Architect in a black shirt. Member Since: 02 Apr 2021 Location: Glasgow Posts: 11 ![]() ![]() |
A quick update on this.
Kot Member Since: 07 Jan 2021 Location: UK Posts: 92 ![]() |
I had a similar issue (L405) and it was under warranty they removed the fuse link for the amp and it worked
DaveTDV8 Member Since: 08 Feb 2022 Location: Dartford Posts: 11 ![]() ![]() ![]() |
You are no longer alone with this issue. Happened to me today. No sound and phone bluetooth not working. Will have a look tomorrow, see what I can see.
Boxers Member Since: 26 Sep 2019 Location: Lincolnshire Posts: 221 ![]() ![]() ![]() |
Had the same thing happen to mine on Saturday, parked it up & did a bit of shopping and everything came back again there was a loud buzzing noise coming from the radio speakers until I turned the radio off before parking up. |
Been out in mine again today and everything works. If it happens again its obviously not the fuse. |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 949 ![]() ![]() ![]() |
I've had the same issues as boxers on a few occasions,,, on startup a horrendous crackling noise from the speakers,, nothing you'd can get rid,, even switching off it still continues. Only fix is to let the car go to sleep and after that it's normally ok. I'm sure I read somewhere it's an issue with the way the systems initialize during startup,,, once in a while things get out of sync and throw a hissy fit. 2010 RRS, TDV8
Hi Gogsy, glad I'm not the only one to have experienced this last year in Devon had the same lost radio etc. Stopped to walk the dog for an hour or so & everything working as normal again ! That's what I've found with this vehicle let it rest and it's back to normal I don't rush to my independent with my problems unless they persist saves a ton of cash 👍 |
Right, quick update on mine. About 1 in 5 starts this problem exists. Most annoying. Its going to be a difficult fault to find all the time it is intermittent. |
I was the OP on this thread.
I don't understand why, but if I leave my system on Radio mode it works every time. Its a ball ache changing to radio every time I pull up, and back to iPod before I pull away, but it works every time (so far). |
