Home > General > Whining sound when I turn the interior fans on
Agent_Trig
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Fuji White
This has just started, its a fairly quiet but noticeable whining sound that comes from the passenger side of the dash when I turn the fans on.
When turned from off to the first notch so you cant really hear the fans themselves, you can hear this whining sound.
Weirdly, when I turn the car off, you can still hear it both inside and outside for a few mins.
Any ideas?
Post #619502 Thu Nov 25 2021 7:23pm
The ECU has a cooling fan and that is on the passenger side of the car against the firewall in the engine bay.
Alternatively, it could be the FBH running - it comes on in low temperatures to speed up the heating of the coolant to help with emissions and also allow earlier heating of the cabin air. 2012 SDV6 - it's missing a couple of cylinders
Post #619513 Thu Nov 25 2021 10:01pm
Agent_Trig
Hmm it might be the latter then.
To give more info as I've found it....
The sounds stops when I turn the climate settings off, so no cabin heating or fans on, the sounds stops dead. Turn the climate back on and it starts again.
This sound is prominent for an entire journey of over an hour.
The sound continues to be heard from the outside for about 5 mins, after the car has been turned off.
Post #619607 Mon Nov 29 2021 12:07pm
I suppose you could pull the FBH's fuse so it won't run and see if the noise persists. 2012 SDV6 - it's missing a couple of cylinders
Post #619608 Mon Nov 29 2021 12:18pm
Agent_Trig
What does FBH mean?
Post #619611 Mon Nov 29 2021 4:01pm
BJH1959
Portugal 2005 Range Rover Sport TDV6 HSE Cairns Blue
Fuel Burning Heater - I think. Barrie.
2017-Jan 2024: 2005 RRS 2.7TDV6. Best car I ever had - until now!
Current: 2018 Ford Ranger Wildtrak 3.2
Post #619612 Mon Nov 29 2021 4:46pm
Agent_Trig
Thanks Smile
Post #619615 Mon Nov 29 2021 4:59pm
Sorry, yes, it's the auxiliary heater that runs on fuel to help heat the coolant in cooler weather conditions. 2012 SDV6 - it's missing a couple of cylinders
Post #619619 Mon Nov 29 2021 6:12pm
Agent_Trig
Yep, it must be the FBH then guys.
Today the outside temp was 9c and the sound never started up at all Smile
Post #619629 Tue Nov 30 2021 1:14pm
Good stuff - thanks for the feedback as it helps the next one. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #619644 Tue Nov 30 2021 7:46pm
