![]() | Home > General > Whining sound when I turn the interior fans on |
The ECU has a cooling fan and that is on the passenger side of the car against the firewall in the engine bay.
Agent_Trig Member Since: 29 Jun 2021 Location: Staffordshire Posts: 43 ![]() ![]() ![]() |
Hmm it might be the latter then.
I suppose you could pull the FBH's fuse so it won't run and see if the noise persists. 2012 SDV6 - it's missing a couple of cylinders
What does FBH mean? |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
Fuel Burning Heater - I think. Barrie.
Thanks |
Sorry, yes, it's the auxiliary heater that runs on fuel to help heat the coolant in cooler weather conditions. 2012 SDV6 - it's missing a couple of cylinders
Yep, it must be the FBH then guys.
Good stuff - thanks for the feedback as it helps the next one. |
