Home > Technical > Front offside driveshaft removal
blueraccoon
Apologies for another post on my quest to replace my offside driveshaft seal.
After a lot of wrestling under the car with various pry bars I finally managed to pop the offside driveshaft out tonight. Brilliant, I thought, I can now get the seal replaced and start putting it back together.
I was swiftly foiled when I tried to remove the driveshaft. Its obviously the longer of the two and, as pictured, there is not enough room to fully remove it as the rear half gets caught between the suspension strut, etc. Try as I might, I cannot find any guides anywhere as to what else I need to remove to be able to get the beast out.
Does anyone else know what I might need to take off so as to be able to extract it? I am thinking possibly the lower ball joint on the hub could be popped out and then the hub dropped lower or removed and this might allow it to come out a bit lower and clear the strut etc?
Thanks
Post #619060 Wed Nov 10 2021 8:04pm
Devon Z
England 2005 Range Rover Sport TDV6 HSE Java Black
Don’t recall having this problem when I did mine, looking at your picture the drop link is still in place, checked the LR workshop manual and it says to remove it. Steve
2005 2.7 TDV6 HSE, ongoing project.
1998 Volvo V70 R auto FWD, mothballed future project.
1999 BMW Z3 (owned from new) garage queen.
Post #619080 Thu Nov 11 2021 11:28am
blueraccoon
Brilliant - thanks very much - will give this a go.
Probably a stupid question but where can I get a copy of the workshop manual?
Post #619081 Thu Nov 11 2021 12:15pm
Iomegas
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi this may help .
https://www.rangerovers.net/threads/2010-2...de.330662/
Post #619086 Thu Nov 11 2021 2:08pm
blueraccoon
Cheers - very useful. Will have a look at this.
Post #619092 Thu Nov 11 2021 4:59pm
Iomegas
Post #619094 Thu Nov 11 2021 6:06pm
Devon Z
I bought an online copy off eBay I’ll see if I can find a link. Steve
Post #619102 Fri Nov 12 2021 9:03am
Devon Z
https://www.ebay.co.uk/itm/Range-Rover-Spo...635-2958-0
Here you go, there’s a few on there this is disc or download. Steve
Post #619104 Fri Nov 12 2021 9:08am
blueraccoon
Thanks, Steve. Got it out now after removing the drop link! Cheers
Post #619132 Sat Nov 13 2021 5:46am
knwatkins
I have a couple of copies of the workshop manual on my Google Drive. Here are some links...
L320 RRS Pre-Facelift
L320 RRS Post-Facelift Kev
Post #619136 Sat Nov 13 2021 9:51am
