Home > General > Front suspension knocking/sensitive issues..... |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 942 |
The first thing that springs to mind given the age of the car,,, and not knowing it's history, is front lower suspension arms. These are a common issue, normally rather than try to fit new bushes the old arms are cut off and new ones fitted,,, saves a lot of time, but 4 wheel alignment must be carried out when this has been done,,,,,,, and it needs to be done by someone with the correct equipment ands knows exactly what they are doing or you will be worse off than you were originally.
Mon Jul 12 2021 6:01pm |
MallorcaNick Member Since: 03 Jan 2021 Location: Mallorca Posts: 50 |
Thank you. Again! 🙏🙏🙏 |
Mon Jul 12 2021 6:45pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
One way to diagnose the lower arm bushes is to drive slowly - around walking pace - and then tap the brakes. You'll hear a knock if the bushes are worn. 2012 SDV6 - it's missing a couple of cylinders
Tue Jul 13 2021 8:11am |
Great advice. Thank you. I'll give it a try.
Tue Jul 13 2021 8:20am |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
You may also consider checking the lower steering column universal joint. They can become stiff and notchey when turning the steering. I take it you have checked the PS fluid level already. |
Tue Jul 13 2021 9:01am |
I've been quoted £450 for parts, labour and realignment.
Mon Nov 01 2021 8:41am |
MarcMGD Member Since: 30 Nov 2020 Location: Essex Posts: 22 |
Mon Nov 01 2021 8:50am |
Quick update: Got the bushes done (although it was about £420!!!) and the car drives so much better. No more knocking noises and it weirdly feels like the power steering is now turned on, if that makes sense.
Tue Nov 09 2021 11:58am |
