![]() | Home > In Car Electronics > Rear view |
alfapat Member Since: 25 Sep 2021 Location: Elgin Posts: 210 ![]() ![]() ![]() |
Thinking of fitting a reverse camera , to either the hatch lock or replace the number plate lense with one .
The problem on the RRS is that you can't get a cable to the no plate light or no. plate. (unless you bodge it on the outside)
Ok thank you for your reply.
an ECU flash is not required. Just a CCF update. But yes, a battery charger should be connected while you do this |
OK Thank you for that , is that ccf update of instrument dash then. Do you know that for sure please, and does it affect the phone module or does it leave alone.
You certainly cannot see the the tow hitch in the o.e. rear view camera fitted in the spoiler on a face-lift RRS1 due to the rake of the rear window/tailgate the best you will see is the rear wiper arm. The extra feature you could get only worked on the D4 due to the shape of the rear.
Ok Cheers that's that ruled out. Cofirmed |
the ccf is stored centrally I think. It basically says what options are fitted to the car. As long as you take precautions of turning interiors lights off, and charging the battery for 1 hour before attempting and during its safe to do.
Sorry not sure what you mean cetrally Andy, looked inGAP and ccf and only see options to Audio but no updates. |
menu selections Something like.
Ok Andy , Thank you will have a go at the w/e, this will be on an RRsport naturally.. So this updates the screen to parking camera only or does it have other improvements.
This only does one thing. Says a camera is fitted.
Ok this looks like I should steer clear, I'll get a separate monitor for the dash.
