![]() | Home > Technical > CLUNKING NOISE WHEN ENGINE SWITCHED OFF AFTER 5 SECONDS |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 ![]() ![]() |
Does the clunk coincide with the suspension 'settling'? I'm wondering if it could be anti-roll bar drop links, which could also explain the occasional dull thunk while driving 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S |
hullstorage Member Since: 19 May 2021 Location: Hull Posts: 6 ![]() ![]() ![]() |
Thanks for reply
Do you mean the noise happened as the suspension dropped? If so and it wasn't drop links, I'd be thinking lower arm bushes - they are also a common fail and result in a clunk when there is a fore/aft load on the arms (which happens during braking but also if the suspension travels while the wheel is stationary).
Transfer case having a moment to itself
after engine off is the EGRs and turbo actuator moving to do their cleaning cycle |
thanks, how do you calibrate ? |
Via diagnostics |
