Home > Technical > V8 tdi Engine sys fault
alfapat
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Been doing a bit of research on the code I have P000E-00. Vehicle runs out of power but will restart, eg. ign/on/off.
There is a volume control valve , how ever I think the code refers to a volume sensor rather than a valve . Can anyone help please , I have a rough idea its on the pump , but not sure .
Post #617714 Sun Sep 26 2021 1:35pm
alfapat
deleted
Post #618388 Mon Oct 25 2021 8:22pm
Boxers
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
Had this on my TDV8 in July of this year when driving back from Devon towing the caravan , took it into my indi who found a split turbo boost pipe a cheap repair to the problem.
Post #618396 Tue Oct 26 2021 6:09am
Oldandconfused
I have no idea what your fault is, however it clearly is a fault and you should be aware of your legal rights, as I've no doubt the garage does!
https://www.themotorombudsman.org/knowledg...rights-act
Be aware of the timescales and I would suggest you make sure your contact with them is recorded (text/email).
If you paid partly or in full with a credit card, you also have protection under S75 of the Consumer Credit Act 1974, the CC company is "jointly and severally liable to the creditor", namely you. The garage will know this but are hoping you don't.
Good luck and don't let them get away with it
Post #618399 Tue Oct 26 2021 7:33am
Agreed. Take it back and tell them to sort it out to your satisfaction. 2012 SDV6 - it's missing a couple of cylinders
Post #618403 Tue Oct 26 2021 9:10am
Shaun W
My TdV8 had a split Intercooler hose, symptoms were black smoke and jumping into Restricted Performance, switching off and on cleared it.
I bought replacement silicone hoses and fitted the top two
myself, took less than 20 minutes, including taking the clips off the old hoses and installing them on the new ones.
Everything seems to be OK now.
I didn’t bother with going back to the garage and I wasn’t 100% sure the warranty covered hoses AND upgrading the hoses seemed a good idea.
Might be worth looking on YouTube to see how to take the hoses off and inspect them, unless you can see the split without. 2010 HSE TdV8 in Stornoway Grey.
Powerful Roof Rails and Spare Wheel protector
Post #618405 Tue Oct 26 2021 9:48am
alfapat
I dont think any of the hoses at fault .
I get small puffs of white smoke on accelerating, so no no black. Without putting the car on LR diagnostics I cant pin it down.
Post #618438 Tue Oct 26 2021 9:06pm
alfapat
Can I ask what would be average fuel consumption for most v8's out there I'm just wandering if mine is too high as I would guess on local 12/24 mile runs should be more than 20 mpg.
I wandering if the faulty sensor has anything to do with it, or perhaps that's the best I can expect.
Post #618848 Sun Nov 07 2021 10:16pm
alfapat
Can I ask what would be average fuel consumption for most, I'm just wandering if mine is too high as I would guess on local 12/24 mile runs should be more than 20.5 mpg.
I am trying to see if my ongoing problem is a consequence of this fault code.
Sorry bit of a typo error with last post!
Post #618849 Sun Nov 07 2021 10:30pm
Nilrem280
United Kingdom 2010 Range Rover Sport TDV8 HSE Nara Bronze
Around town, I can get up to almost 22mpg if I drive like Miss Daisy.
Post #618859 Mon Nov 08 2021 7:51am
Boxers
Worst is 19mpg best is 30mpg.
Post #618862 Mon Nov 08 2021 8:51am
alfapat
Oh well , just trying to work out if this fuel volume sensor might help me solve this issue.
Post #618943 Mon Nov 08 2021 11:45pm
alfapat
OK , looking for a good guide to replace the drivers side intake manifold , its cracked, This will no doubt be the trouble behind the fault , at last. The seller has agreed to give me a replacement but not the fitting.
Anyone done this and how long does it take.
Sorry V8 3.6tdi
Post #620147 Mon Dec 20 2021 4:32pm
alfapat
The first fault showing the engine faults would I think relate and cause the other faults. Any help appreciated!
I have just fitted a new inlet manifold and I get these faults after the rebuilt , I tried to erase on Gap but its not happening . I have checked all the plugs I had disconnected but nothing obvious there eit
Post #620437 Sun Jan 02 2022 6:24pm
alfapat
Sorry the last picture would be the fault to go on. So looking for help.
Fault found with above picture related was 37 fuse. Seems it was responsible with a whole list of things.
However after all the work the P000E code is still there.
Post #620472 Mon Jan 03 2022 11:00am
