Home > General > 2010 TDV8 cranks but doesn't start
Page 2 of 3 <123>
aaronjb
Yes! Thank you Smile
Definitely means there is low voltage in the ECU for some reason - either high voltage drop on the feed or ground side, or dead internally.
At least I know I'm looking at the right ECU now! 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #618329 Sat Oct 23 2021 8:37pm
aaronjb
By the way, I take it that was with the engine running given 14.5V. Do the numbers stay broadly the same with the engine off and just the ignition on? 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #618330 Sat Oct 23 2021 8:39pm
Nilrem280
United Kingdom 2010 Range Rover Sport TDV8 HSE Nara Bronze
Ignition On - Engine Off.
Post #618331 Sat Oct 23 2021 8:46pm
aaronjb
Thanks! Definitely something wrong with my PCM then, either external voltage drop or internal.
Let's hope external as that would be much cheaper to fix, although could be harder to find. Otherwise it's time to get the PCM cloned unless anyone has a complete set (I think PCM, junction box and clocks) from a 2010 TDV8.. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #618334 Sun Oct 24 2021 7:23am
aaronjb
Belled out all of the feeds (0Ohms to the relay) and the grounds (0Ohms to ground). I will admit I haven't tried back-probing the connector yet to make sure +12v is actually present and there isn't a low voltage feed for some reason but while googling I found this:
https://www.turnermechatronics.com/range-r...start.html
Which sounds awfully familiar! Time to call Turners on Monday, I think. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #618340 Sun Oct 24 2021 5:13pm
Nilrem280
It does sound like the issue you have, hopefully they can resolve it for you.
As you have an IID tool can the guy's at GAP not help you out with a flash file?
Post #618346 Sun Oct 24 2021 8:15pm
aaronjb
I don't think it's a software issue unfortunately - I think the DC regulation breaks down internally.. I did speak to the chaps at Turners this morning though and they reckon they can resolve it either via exchange or repair in 99% of cases, so I'll pull the PCM and post it off to them next week; this week I think I'd rather concentrate on worrying about my wedding on Thursday! Smile
Thanks for the help though - I really appreciate that; it confirmed which component has the problem, ultimately. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #618362 Mon Oct 25 2021 1:33pm
aaronjb
£600 later for a recon ECU and .. no change at all.
Still a full list of CANbus faults and no start.
Crusher next, I think. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #619453 Wed Nov 24 2021 11:41am
Boxers
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
Oh dear doesn't sound good , I have an excellent indi in Peterborough not that far from you really Avenger 4x4 give them a call & speak to Alan I'm sure he could help very knowledgeable.
Post #619454 Wed Nov 24 2021 12:11pm
aaronjb
Cheers - if it's getting repaired I think it'll definitely need a specialist indy (or a very good auto electrician) to find the fault .. somewhere. Otherwise I'll end up just randomly swapping ECUs because I can't find a wiring fault :/
£160 to recover it from here to Peterborough.. shame I don't have a car that could tow .. my tow car Rolling Eyes 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #619459 Wed Nov 24 2021 2:10pm
RugHead
United Kingdom 2013 Range Rover Sport SDV6 HSE Lux Orkney Grey
Hi mate, don't know if it'll help, but I have a 2012 with the rotary gear selector, a month ago it had a bit of a hissy fit where the car would start but the selector was dead didn't rise and no LEDs came on, luckily it righted it self after about half an hour and has been perfect since, my son ran it past his friend who works at a local dealership, he seemed to think it could have been a problem on the canbus, he advised I check the earth points under the wing because they're seeing alot of canbus faults on older cars due to the earth's, worth a try.
Post #619460 Wed Nov 24 2021 3:35pm
aaronjb
Yep worth a try - I belled out the earths to the PCM as all good, but it could be an earth to something else.
Checking fault codes again and I have the exact same list as before, plus the DC/DC Converter voltage is ~5V and PCM battery voltage reports as ~4V (despite 12V in).
ATCM-Terrain Response
U0139-00 (2F) Lost communication with the suspension control module B
( on 24-11-2021 17:36:31 at 185626 km )
BCM-Body Control
( on 24-11-2021 17:36:32 at 185626 km )
IPC-Instrument Pack
U0104-00 (2F) Lost communication with speed control module
( on 24-11-2021 17:36:36 at 185626 km )
U0133-00 (2F) Lost communication with dynamic response module
U0139-08 (2F) Lost communication with the suspension control module B - General failure information - bus signal/message failure
RLM-Suspension
( on 24-11-2021 17:36:41 at 185626 km )
Everything in the workshop manual still points to a CAN fault.. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #619467 Wed Nov 24 2021 6:20pm
aaronjb
Happened to be around the corner today (taking my dad to his oncology appointment) so stopped for a chat with Alan.. can see why it was convenient for you! Wink
He can look at it mid December.. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #619484 Thu Nov 25 2021 12:36pm
Boxers
Good to hear if anybody can sort it they can.
Post #619501 Thu Nov 25 2021 6:06pm
aaronjb
Car is now at Avenger 4x4 so .. I'll let you know how much lighter my wallet gets shortly! Laughing (It's already £168 lighter from recovering it there) 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #619877 Fri Dec 10 2021 3:17pm
Page 2 of 3 <123>
