![]() | Home > General > C-TEK charger |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5042 ![]() ![]() ![]() |
Welcome, Left mine on 3 months at a time when used to work overseas and never had any problems of any kind.
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 469 ![]() ![]() ![]() |
Use mine when I know car won’t be used for a couple of weeks. No problems at all. I would say it does it good. It’s the only time the stop start works once been hooked up for a day. |
neil12ne Member Since: 25 Nov 2018 Location: Merstham Surrey Posts: 8 ![]() ![]() ![]() |
Great thanks guys.
I’m pretty certain the car tells you the battery is low and to start the engine to charge the battery. It certainly tells you when you get in the car via the display screen . Almost certain it tells you on your phone too via incontrol app. |
Ctek charger, comfort connector, job done. |
Ken 153 Member Since: 02 Sep 2021 Location: Sheffield Posts: 188 ![]() ![]() ![]() |
What's the incontrol App out of interest?? |
The Incontrol app is not compatible with the RRS1 and will not work on that model, unless someone has found a way of installing it.
Sorry , should have said the app is only for L494 variants |
