Home > Faults & Fixes > Amber warning for suspension Fault on start up?
Martek
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Stornoway Grey
Hi Guy's
2012 SDV6.
Amber warning for suspension error on start up.
If i switch ignition off and back on, it will clear.
Every now and then when driving i get the same error, but clears when i re-start.
Normal ride height etc
Any ideas please?
Thank you
Regards Dave
Post #618009 Sun Oct 10 2021 6:31pm
Boxers
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
Have this regularly on my TDV8 had it checked twice by my indie when in for servicing, everything works normally like yours turn it off & the warning goes so I just live with it now.
Post #618012 Sun Oct 10 2021 7:10pm
gogsy1956
I used to get the same issue which was getting more and more frequent, especially when lowering or raising the suspension,, when this happened it always turned off the forward alert function. I bought a full service kit off eBay for the compressor and changed all seals, dessicant, piston ring and delivery valve,,,, which I think is the main problem. Some filters have to be cleaned rather than replaced but it's worked 100% better since. I am also working through the seals in the valve blocks. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #618013 Sun Oct 10 2021 7:29pm
Exhaust valve in the suspension compressor will cause this fault. Generally considered a new compressor is required. 2012 SDV6 - it's missing a couple of cylinders
Post #618015 Sun Oct 10 2021 7:48pm
Mickmac
England 2007 Range Rover Sport TDV6 HSE Java Black
I had a similar issue with my 2007 sport ,had it checked by local indie who emailed lr with the fault code ,it turned out it was the lateral accelerometer situated on the chassis under the drivers seat ,replaced for about £ 80 inc fitting no more fault light !
Post #618018 Sun Oct 10 2021 9:24pm
