Home > Faults & Fixes > Amber warning for suspension Fault on start up? |
Boxers Member Since: 26 Sep 2019 Location: Lincolnshire Posts: 220 |
Have this regularly on my TDV8 had it checked twice by my indie when in for servicing, everything works normally like yours turn it off & the warning goes so I just live with it now. |
Sun Oct 10 2021 6:10pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 942 |
I used to get the same issue which was getting more and more frequent, especially when lowering or raising the suspension,, when this happened it always turned off the forward alert function. I bought a full service kit off eBay for the compressor and changed all seals, dessicant, piston ring and delivery valve,,,, which I think is the main problem. Some filters have to be cleaned rather than replaced but it's worked 100% better since. I am also working through the seals in the valve blocks. 2010 RRS, TDV8
Sun Oct 10 2021 6:29pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
Exhaust valve in the suspension compressor will cause this fault. Generally considered a new compressor is required. 2012 SDV6 - it's missing a couple of cylinders
Sun Oct 10 2021 6:48pm |
Mickmac Member Since: 15 Jun 2018 Location: Amble Posts: 16 |
I had a similar issue with my 2007 sport ,had it checked by local indie who emailed lr with the fault code ,it turned out it was the lateral accelerometer situated on the chassis under the drivers seat ,replaced for about £ 80 inc fitting no more fault light ! |
Sun Oct 10 2021 8:24pm |
