Home > General (L494) > Coolant leak. |
MartW Member Since: 22 Mar 2021 Location: Warwickshire Posts: 14 |
It's got to be the intercooler. But why is there water there? I'm putting a lot of water in the coolant filler each day, and water drips out from the bottom of the plastic cowling attached to the intercooler. There is a metal pipe running towards/under the bottom and is concealed by the plastic attached to the bottom of the intercooler... |
Wed Oct 06 2021 5:24pm |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1167 |
you don't mention which engine you have, but the crossover coolant hoses are notorious for cracking, resulting in a slow leak.
Wed Oct 06 2021 7:46pm |
Ah, yeah 3.0TD V6 306hp, late 2015.
Wed Oct 06 2021 8:30pm |
Had the coolant crossover pipe and water pump replaced (preventative measures) - R12k later. --
Mon Oct 25 2021 4:59pm |
I still don't know what the issue is/was since it just stopped leaking all by itself before I had a chance to get the garage to have a proper look at it. I think in my case there is likely a leak in a coolant pipe that goes somewhere down near the bottom of the intercooler on the off side. |
Mon Oct 25 2021 5:11pm |
