kas982
when you sit inside the vehicle, check all the electric stuff works, click all the switches, turn on all the lights.
check the 4x4 sytem works ( low range ), check the terrain response works.
check interior for wear/tears, pull the sunroof blind closed. on test drive check for knocks, rattles, whurring coming from outside the car.
test the suspension works, set in high position & leave it there, check under the car for corrosion.
listen to engine at idle for knock or rattles, rev to 2500 - 3000, should be smooth no hesitation or any rattles or knocks.
if buying a 4.2 a light knocking sound that goes quiet when reving is possibly down to the supercharger being faulty.
never buy a vehicle with body rot!
Tue Oct 05 2021 2:20am |
