Home > Technical > Upper tailgate intermittent bottom always works? My2010 |
Ken 153 Member Since: 02 Sep 2021 Location: Sheffield Posts: 188 |
Someone said on one of my posts - that the switch can get water in it.
Sun Sep 19 2021 12:23pm |
SomersetRRS Member Since: 18 Nov 2019 Location: Somerset Posts: 65 |
I think water in the pull mechanism is a common problem. Went investigating when mine didn't work and found someone had already been in there and disconnected it! |
Sun Sep 19 2021 1:42pm |
jases4x4 Member Since: 28 Dec 2014 Location: yorkshire Posts: 225 |
Its back working today but i would say it stops after some rain but when i took the switch off it looked sealed and all good. |
Sun Sep 19 2021 4:37pm |
Would that mean a new lock mechanism the top one? Or a new switch the button under the top tailgate would you say? |
Sun Sep 19 2021 4:39pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 948 |
I think I would start with a new switch ( upper glass tailgate section) as this always appears to be the weakest link. Do make sure the lower tailgate is fully closed and latched otherwise the top section will not open. I've had an instance when the main tailgate wouldn't completely latch,,, cleaning and adjusting the striker plate mechanism cured it 2010 RRS, TDV8
Sun Sep 19 2021 5:06pm |
I have pm’d advance parts for the tailgate switch but im not sure if its that now because the bottom button for tailgate has also stopped working so i can only open boot with the remote boot open switch, Any advice on the fault guys? |
Sat Oct 30 2021 5:29pm |
Ordered a cheap switch of ebay and it came with the wrong plug think it was the freelander one but the switch is same soci swapped the plug and bingo fixed it like a few suggested. Cheers 👍 |
Fri Nov 05 2021 11:09pm |
