Home > Technical > Upper tailgate intermittent bottom always works? My2010
jases4x4
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Santorini Black
Hi Guys done alot of searching but cant find the exact fault im having.
My bottom tailgate always works if i use remote or press the button no problems there.
Its the upper tailgate thats intermittent, some times it opens and sometimes it doesnt more doesnt these days so i need to fix it asap, I think its probably the switch or upper latch, Has anyone had exact issue or know what the fault will be? Thanks
Post #617459 Sun Sep 19 2021 11:02am
Ken 153
United Kingdom 2010 Range Rover Sport Supercharged HSE Galway Green
Someone said on one of my posts - that the switch can get water in it.
Don't know if this helps or not.
Post #617460 Sun Sep 19 2021 12:23pm
SomersetRRS
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
I think water in the pull mechanism is a common problem. Went investigating when mine didn't work and found someone had already been in there and disconnected it!
Post #617465 Sun Sep 19 2021 1:42pm
jases4x4
Its back working today but i would say it stops after some rain but when i took the switch off it looked sealed and all good.
Post #617469 Sun Sep 19 2021 4:37pm
jases4x4
Would that mean a new lock mechanism the top one? Or a new switch the button under the top tailgate would you say?
Post #617470 Sun Sep 19 2021 4:39pm
gogsy1956
I think I would start with a new switch ( upper glass tailgate section) as this always appears to be the weakest link. Do make sure the lower tailgate is fully closed and latched otherwise the top section will not open. I've had an instance when the main tailgate wouldn't completely latch,,, cleaning and adjusting the striker plate mechanism cured it 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #617472 Sun Sep 19 2021 5:06pm
jases4x4
I have pm’d advance parts for the tailgate switch but im not sure if its that now because the bottom button for tailgate has also stopped working so i can only open boot with the remote boot open switch, Any advice on the fault guys?
Post #618543 Sat Oct 30 2021 5:29pm
jases4x4
Ordered a cheap switch of ebay and it came with the wrong plug think it was the freelander one but the switch is same soci swapped the plug and bingo fixed it like a few suggested. Cheers 👍
Post #618787 Fri Nov 05 2021 11:09pm
