Home > Faults & Fixes > 2009 Both front doors not locking |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 946 |
Hi and welcome, I believe the door locks are not an uncommon problem. I actually have an issue with mine at the moment,, won't lock off the door button so have to resort to the fob,, but unlocking isn't a problem. It's the drivers door on mine but just not got round to it yet, most likely a new latch mechanism required as I don't think it's a serviceable part. 2010 RRS, TDV8
Sun Sep 19 2021 10:52am |
Iain6023 Member Since: 14 Sep 2021 Location: Southeast Posts: 11 |
Hi. They seem cheap enough to buy. Wasn't sure as it was both whether they were on a common supply or earth etc. Somethings obviously getting through as both unlock just not lock. |
Sun Sep 19 2021 10:59am |
Have a look on U tube,, few articles on there especially n removing the door card and getting access to the mechanism which can save you a lot of time as some of the fixings are well hidden. I think there is a difference in price if you are buying for keyless entry type so make sure you have the correct one.,,, whatever you buy don't do cheap and cheerful . Use the search function on here,, door lock will bring up a lot of posts and you will see the problems others have had,,, and maybe a solution. 2010 RRS, TDV8
Sun Sep 19 2021 4:41pm |
I'll have a look and see what's there. Many thanks for replying. Just want to clear up any niggles on what is an awesome car. |
Sun Sep 19 2021 5:37pm |
