![]() | Home > General > L320 Side Steps |
No sure about the rivet size but would suggest you use stainless steel replacements instead of the alloy one's which corrode away.
Ken 153 Member Since: 02 Sep 2021 Location: Sheffield Posts: 188 ![]() ![]() ![]() |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 949 ![]() ![]() ![]() |
Trying to remember when I did mine,,, probably around the 3mm mark,,, I would clean the holes out and use as big as you can. I used self tappers and a big washer when I put mine back together. 2010 RRS, TDV8
5.5 mm drill bit & done a before and after picturs that will follow soon..
