Home > General > L320 Side Steps
Ken 153
United Kingdom 2010 Range Rover Sport Supercharged HSE Galway Green
L320 Side Steps
Any one know hat size the rivets are that hold on the ali side trim?
One of mine has just fallen off - so using the opertunity to clean them both up and re-attach them.
Post #617432 Sat Sep 18 2021 10:38am
No sure about the rivet size but would suggest you use stainless steel replacements instead of the alloy one's which corrode away.
Post #617433 Sat Sep 18 2021 11:10am
Ken 153
Post #617435 Sat Sep 18 2021 11:15am
gogsy1956
Trying to remember when I did mine,,, probably around the 3mm mark,,, I would clean the holes out and use as big as you can. I used self tappers and a big washer when I put mine back together. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #617445 Sat Sep 18 2021 6:00pm
Ken 153
5.5 mm drill bit & done a before and after picturs that will follow soon..
Thanks for the reply.
Post #617447 Sat Sep 18 2021 6:58pm
