Home > General > Air Bag Light -Novice Question |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4968 |
Could be something to do with the occupancy sensor in the seat, anything to do with the SRS system I would be inclined to get the codes read as this may point you in the right direction.
Fri Sep 17 2021 12:21am |
Ken 153 Member Since: 02 Sep 2021 Location: Sheffield Posts: 188 |
Thanks.
Fri Sep 17 2021 12:29am |
If you intend keeping the vehicle some time I personally would suggest you invest in a Gap diag. tool, even if you sell the vehicle there is a good s/h market for the tools so you could probably re-coup a lot of the cost. When you consider labour rates especially at main stealers it wouldn't take long for it to pay for itself really, in addition if it did have to go to a dealer you would have a heads up of the possible problem instead of the rip off bull**** the dealer will give you and try to charge you a fortune.
Fri Sep 17 2021 1:33am |
Thanks for the info.
Fri Sep 17 2021 1:40am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4940 |
You can get an Autel AP200 White code reader for between £44 (direct) and £70 (amazon)
Fri Sep 17 2021 9:36am |
