Home > Maintenance & Modifications > Gearbox , diffs and transfer box oil service |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
Head over to the disco4 forum. Link at the bottom.
Wed Sep 15 2021 3:50pm |
Crraigymmmmm Member Since: 06 May 2021 Location: Peterborough Posts: 163 |
Thanks Andy, I guess those boys are a little more hands on than the normal RR owner |
Wed Sep 15 2021 4:10pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 942 |
If your planning on keeping the car for a while why not bite the bullet and just get a gearbox flush,,,, better than faffing on with partial changes. An indie could do all your diffs etc in no time, hardly worth the trouble doing it yourself,, by the time you get the correct oil, and scramble about underneath you'll probably not really save yourself very much 2010 RRS, TDV8
Wed Sep 15 2021 4:29pm |
Thanks, thats the route I was going to go but ZF told me to avoid flushing if there are no problems currently as this could introduce issues, He told me that flushing is a last resort if you are having problems and a partial fluid change doesnt cure it. |
Thu Sep 16 2021 7:03am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8978 |
Strange that the ZF agent would be against changing the gearbox oil. The manufacturer themselves say the oil should be changed.
Thu Sep 16 2021 7:33am |
Thanks for that, did you flush it or get the oil dropped and refilled? did you recall the oil condition at 75K? |
Thu Sep 16 2021 9:01am |
I had it flushed by my indie. No idea what the old oil was like, sorry. But I did have my old TDV8 flushed on my driveway by a forum member, Geoff, several years ago. That oil was pretty dark compared to the new stuff, so I would guess the oil will be quite dark in all gearboxes that have done 70k miles. 2012 SDV6 - it's missing a couple of cylinders
Thu Sep 16 2021 9:25am |
If you wait until your having issues to get a flush,,,, as ZF have suggested,,,, I would say it's already to late. Prevention is the key. 2010 RRS, TDV8
Thu Sep 16 2021 6:23pm |
Indeed prevention is better than cure. How can clean oil not be a good thing. Just in a flush more than a full oil change? I.e does is just change all the oil or does it blast the internals? |
Thu Sep 16 2021 7:09pm |
The flush just pumps fluid around. There is no "blasting" really.
Thu Sep 16 2021 7:23pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
As others have said, ZF recommend lower mileage or age intervals than LR so no idea what you’ve been told.
Thu Sep 16 2021 7:46pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
As you asked about DIY...
Thu Sep 16 2021 8:24pm |
That's brilliant! Thanks. |
Fri Sep 17 2021 7:35am |
