Home > General > Wade sensing retro fit
mxdiff
Hi
Does anyone know if it possible to retro fit the wade sensors to a 2018 RRS Autobiography? It has the surround cameras and blind sport monitoring already.
Sensors are available at Powerful UK for £19. Can I fit these and then get it enabled via the GAP diagnostic tool?
Post #595121 Tue Feb 18 2020 1:44pm
Brit Plumber
You will need the correct bottom panel on the mirrors but it’s not available as a spare so you may need to find them as empty units on eBay. I also don’t think you will have the wiring so will need to install that too. Once you’ve done that it should just need the CCF editing. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #595876 Sun Mar 01 2020 9:15pm
Wrecker79
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Sumatra Black
So..... how did you get on with the retro-fit?
Post #617226 Mon Sep 13 2021 8:37am
