Wade sensing retro fit
Hi
Does anyone know if it possible to retro fit the wade sensors to a 2018 RRS Autobiography? It has the surround cameras and blind sport monitoring already.
Sensors are available at Powerful UK for £19. Can I fit these and then get it enabled via the GAP diagnostic tool?
Tue Feb 18 2020 2:44pm
Brit Plumber
You will need the correct bottom panel on the mirrors but it’s not available as a spare so you may need to find them as empty units on eBay. I also don’t think you will have the wiring so will need to install that too. Once you’ve done that it should just need the CCF editing.2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Sun Mar 01 2020 10:15pm
Wrecker79
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
