Home > In Car Electronics > Battery keeps going flat
Ken 153
United Kingdom 2010 Range Rover Sport Supercharged HSE Galway Green
Is there a common issue that causes the battery to drain.
I know on some older cars like MK2 golfs that the glove box & boot light is a common issue for flattening the battery, is these something similar on a 2010 RRS?
I have read the thread about YASU batteries failing and mine has one fitted but the AA man says its not showing issues of it failing.
TIA
Post #617203 Sun Sep 12 2021 4:54pm
Does yours have the split tailgate (the glass is openable separately from the main boot lid). If so, the switch is known to corrode and can cause a drain. 2012 SDV6 - it's missing a couple of cylinders
Post #617214 Sun Sep 12 2021 8:36pm
I see on another post that you have the split tailgate. So that might be worth a look. Also, you're looking for a spoiler trim piece. There is wiring behind the spoiler and if it's broken and letting water in, that might cause corrosion in a connector or similar. The connector for the heated rear glass in in there and known to corrode over time leading to non-working defrosting of the rear glass. 2012 SDV6 - it's missing a couple of cylinders
Post #617215 Sun Sep 12 2021 8:40pm
Ken 153
Yes split tailgate.
Which switch di you mean? the handle under the glass to open the top glass?
Spoiler all looks good - replaced the camera today thats why i know its broken.
Thanks
Post #617216 Sun Sep 12 2021 9:30pm
Yes, the rubber switch to open the glass. It is known to corrode. Do a search on the forum and you'll find some how-to posts in there. 2012 SDV6 - it's missing a couple of cylinders
Post #617232 Mon Sep 13 2021 12:09pm
Ken 153
Thanks Thumbs Up
Post #617236 Mon Sep 13 2021 12:56pm
