Home > In Car Electronics > L494 headunit upgrade
Latto
Hi everyone
Total noob here so apologies if this has been asked and answered already
I’m about to buy a 2016 RRS HSE Dynamic after 10 years of Mercs. Took the car for a test drive at the weekend and absolutely loved it but the infotainment system leaves quite a bit to be desired! Not a surprise given it’s older tech and I’m coming from a 2020 model but I’ve managed to get a good deal so have a bit extra cash to upgrade it to something with apple carplay.
I’m not convinced about the unique auto developments option as that seems to use the existing hardware and I’ve read a few negative comments about speed and responsiveness
The 10.25” android unit seems to fit the bill - anybody had one fitted? Thoughts?
Is there a problem getting a more generic aftermarket headunit from the likes of kenwood or pioneer? I imagine the biggest problem would be losing any functionality that’s accessed through the original unit but the car I’m buying doesn’t have many “extra features” (as land rover call them) so I could live with that. Any other problems it might bring?
Any other thought, options or experiences would be very gratefully received!
Thanks
Post #616775 Tue Aug 24 2021 6:50am
the Android units are your best bet, nothing else on the market (that I know of) that will retain all the OEM functions --
Post #616777 Tue Aug 24 2021 8:25am
scarey
you might find this interesting from the fullfatrr forum...its for the l405 but i'm sure they do a l494 version,
https://www.fullfatrr.com/forum/topic60416.html
Post #616780 Tue Aug 24 2021 8:51am
Latto
Thanks folks. Anyone had an android unit fitted to their car?
Post #616781 Tue Aug 24 2021 9:12am
Latto
Update - spoke to a local bloke who specialises in aftermarket in-car tech. He reckons all non-branded android units are to be avoided and recommended a “box” to add carplay to the OEM system. I’m going to follow his advice and I’ll let you know how it goes….
Post #616805 Wed Aug 25 2021 6:17am
scarey
did he say what 'box' and how much?
Post #616806 Wed Aug 25 2021 7:57am
Latto
He didn't say which box but reckoned c£650
Post #616807 Wed Aug 25 2021 9:20am
Latto
That’s the unit fitted
This is the thing - https://id-core.co.uk/product/land-rover-r...interface/
Zak from VTI Solutions in Perth charged £650 including fitting (which took a couple of hours)
Just had a quick play with it and am very impressed - quicker than the built in LR system. Only downside is that it uses the existing touchscreen so, obviously, it’s no more responsive. Overall though, v happy!
Post #616947 Wed Sep 01 2021 2:51pm
scarey
so tempting..thanks for the update.
Post #616949 Wed Sep 01 2021 3:04pm
Chris Qld
Australia
Range Rover information upgrade that goes “Above and Beyon
If you have a moment please take the time to visit the thread of slaine “Android 10.25" Infotainment upgrade “ https://www.evoqueownersclub.co.uk/. A very forthright guy who clearly has a good understanding of the subject far beyond installing a dongle.
Post #617021 Sun Sep 05 2021 9:33am
SkyWalker
Netherlands 2005 Range Rover Sport TDV6 HSE Buckingham Blue
Hello Latto,
How did it work out for you after now one year of usage?
I´m looking at the same box to upgrade my system, however, I´ve read that you can suffer a loss of sound quality due to the fact that the sound is connected via av simple Aux connection.
Is that on all systems offered or are there different (better ones) in the market?
Thanks SW
Sometimes it is not enough to do our best;
sometimes we must do what is required.
Adriatic Blue 2005 RRS HSE 2.7 TDV6
Now: 2016 RRS HSE DYNAMIC 3.0 TDV6
Post #629497 Thu Dec 29 2022 5:50pm
Latto
It was pretty good (have since changed cars). Didn’t notice a difference in sound quality but car had the standard system and I had the carplay unit fitted soon after getting the car.
More generally, the system worked well and I FAR preferred it to the standard. A few things to note tho…
- the sat nav works off your phone and you lose the use of the standard sat nav. In most ways it’s loads better but does use your data and, if you don’t have a mobile data signal when inputting your destination, it won’t work
- linked to the last point, I had to get a dash mount for the phone so it could ‘see’ satellites as it couldn’t otherwise
- you still use the built-in screen so it’s still as irritatingly unresponsive!
All in all though, as I say, much preferred it to the OEM system
Post #629498 Thu Dec 29 2022 6:55pm
Karlp606
For anyone wanting to retain oem but add CarPlay check here
https://www.dmpcardesign.com/for-land-rove...-mirroring
Post #629520 Sat Dec 31 2022 11:46am
Dave-t
I have never seen car play in a car, so in simple terms, what does it do, in real life what do you actually use that the standard fit doesn’t do, and what are the downsides, there must be some? Joined the X5 45e club
1994 Defender 90 300 tdi
Post #629539 Sat Dec 31 2022 10:26pm
Johnrrs
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Zambezi Silver
I have car play in my van and the only thing I use it for is Sat Nav. The car play needs the phone to be plugged into the USB port to work so it doesn’t work via Bluetooth so I don’t know if that’s the same for every vehicle fitted with car play.
Post #629545 Sun Jan 01 2023 10:23am
