![]() | Home > Technical > Suspension Height |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
over thinking it.
andy1972 Member Since: 21 Jul 2021 Location: mojacar Posts: 5 ![]() ![]() ![]() |
Many thanks for your reply, makes perfect sense. |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9028 ![]() ![]() ![]() |
It's worth remembering that height calibration is done using the height between the centre of the axle and the underside of the wheel arch. Thus the size of the wheel is actually entirely irrelevant to the height calibration.
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 ![]() ![]() |
Mine is a 2005 4.2L supercharged and came with 20 inch wheels as standard as far as I know.
Boxers Member Since: 26 Sep 2019 Location: Lincolnshire Posts: 222 ![]() ![]() ![]() |
Mine is a 2007 TDV8 HSE and came as standard with 20 inch wheels. |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1860 ![]() ![]() |
My 2006 came with 19 inch wheels. 2023 P440e SE Dynamic on order -cancelled
A 2006 SE might even have come with 18s, I think. 2012 SDV6 - it's missing a couple of cylinders
Yeah the tdv6 would have had 19” |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 ![]() ![]() ![]() |
I'm sure I read somewhere that 20" wheels should not be fitted on the 2.7 pre-facelift L320's because the steering rack is not up to the job. |
The early 2.7 didn't have the uprated steering rack that the V8 petrol and diesel had from day 1. They fitted it around 2008-9(?) to the 2.7 so they then all had the same rack.
Many thanks to everyone for your replies, very helpful. Cheers. |
