Home > General > Not cooling..chuffing typical. |
idi Member Since: 19 Nov 2019 Location: England Posts: 134 |
My AC needs regassing every summer. There must be a small leak somewhere but for the sake of £30 a year it isn't worth the bother. |
Thu Jun 03 2021 9:10pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 942 |
Blocked matrix is a common problem but so are the blend motors that basically divert or mix the air,,,, I think 2010 RRS, TDV8
Fri Jun 04 2021 4:19pm |
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 |
And then to top it all off I left the sunroof slightly open and it's rained all day so now the the roof switch panel is full or water which is dripping onto the radio etc.. |
Sat Jun 05 2021 4:54am |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
Wow, want a box of matches 2006 2.7 TDV6 HSE in Cairns Blue. |
Sat Jun 05 2021 5:19am |
Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 314 |
Man someone’s having a bad day😳 I hope it improves for you🤞?
Sat Jun 05 2021 9:10am |
No it hasn’t improved.
Fri Jul 30 2021 9:15pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4970 |
Not sure about the pre-facelift, but on the facelift always thought it pretty stupid that you can lock the car, arm the alarm and actualy leave the sunroof ajar or wide open and no "beep" or anything to indicate it is open, they even forgot to include closing the sunroof software in the global closing feature. Cheers Col |
Fri Jul 30 2021 9:58pm |
Agreed. I did it again last week. It seems to be only if the sunroof is tilted that is doesn't quite close fully. If it's slid back then closed its OK.
Sat Jul 31 2021 5:22am |
Even on my old P38 the sunroof closed with the global closing.
Sat Jul 31 2021 6:49am |
Well, it's in the local garage having a new condenser fitted and a new heater matrix. He reckons that the latter is a doddle to install.. We shall see. |
Fri Aug 13 2021 5:03am |
Ok here we go..
Sat Aug 14 2021 4:31am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4943 |
I think you need a nissans matrix.
Sat Aug 14 2021 4:46pm |
