![]() | Home > General > Not cooling..chuffing typical. |
idi Member Since: 19 Nov 2019 Location: England Posts: 134 ![]() ![]() |
My AC needs regassing every summer. There must be a small leak somewhere but for the sake of £30 a year it isn't worth the bother. |
Blocked matrix is a common problem but so are the blend motors that basically divert or mix the air,,,, I think 2010 RRS, TDV8
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 ![]() ![]() ![]() |
And then to top it all off I left the sunroof slightly open and it's rained all day so now the the roof switch panel is full or water which is dripping onto the radio etc.. |
Wow, want a box of matches |
Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 315 ![]() ![]() ![]() |
Man someone’s having a bad day😳 I hope it improves for you🤞?
No it hasn’t improved.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
Not sure about the pre-facelift, but on the facelift always thought it pretty stupid that you can lock the car, arm the alarm and actualy leave the sunroof ajar or wide open and no "beep" or anything to indicate it is open, they even forgot to include closing the sunroof software in the global closing feature. Cheers Col |
Agreed. I did it again last week. It seems to be only if the sunroof is tilted that is doesn't quite close fully. If it's slid back then closed its OK.
Even on my old P38 the sunroof closed with the global closing.
Well, it's in the local garage having a new condenser fitted and a new heater matrix. He reckons that the latter is a doddle to install.. We shall see. |
Ok here we go..
I think you need a nissans matrix.
