Home > General > Front lower arms replacement
Agent_Trig
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Fuji White
Other than genuine LR parts (very expensive), what other brands do people recommend to replace the front lower arms?
Seems to be a lot out there with various pricing but no way to tell how well made they are.
Any recommendations?
Post #616177 Tue Jul 27 2021 3:50pm
You could just go for OEM - basically the same items as LR branded ones but without the added cost of the LR logo on the box. Same maker, different box.
Advanced Factors, for example, does a complete fitting set with a pair of OEM arms, bolts etc., for the price of a single LR arm. Or Meyle HD ones with a 4 year warranty for the same price.
https://www.advancedfactors.co.uk/front-lo...-141-c.asp
I wouldn't go down the cheap stuff from ebay - the arms take a hammering and the bushes are almost consumable items so you may as well put decent stuff on - you'll only have to do it again sooner with cheap stuff.
As they say - buy cheap, buy twice. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #616179 Tue Jul 27 2021 4:23pm
Agent_Trig
This is great advice, thanks.
Those prices are way cheaper than genuine LR too.
Would you rate the OEM better than Meyle if you had to choose?
Or would these be even better...
https://www.advancedfactors.co.uk/kit600t-...5292-p.asp
They come with the bushes and a 4 year warranty for not much more money.
Post #616182 Tue Jul 27 2021 7:05pm
I tried a set of the Poly Bushed ones first and didn't like them seemed a little harsh to me personally, so changed them for the Meyle ones, as said personally found them better, absolutely no issues with Meyle one's quality or fit, must have fitted them a couple of years ago now and still fine.
Post #616184 Tue Jul 27 2021 9:21pm
knwatkins
Another vote for the Advanced Factors arms, fitted with the Meyle HD bushes Thumbs Up Kev
Post #616188 Wed Jul 28 2021 4:00am
Worth remembering also that the longevity of replacements will be helped by installing them correctly. I bet a few garages just torque up the bolts with the suspension in full droop. Should be done with the suspension at normal road position. Tightening them up in droop puts the bushes under more stress when the car is sitting normally so they'll fail sooner. 2012 SDV6 - it's missing a couple of cylinders
Post #616189 Wed Jul 28 2021 6:59am
Agent_Trig
Thanks for the advice guys, going with the Meyle HD arms Smile
Post #616196 Wed Jul 28 2021 11:28am
Just out of interest, if I read a previous post correctly you have only had the vehicle a little over a week so why are you replacing the front arms, if they need replacing so quickly surely the dealer should be paying for this, assuming you bought it from a dealer.
Post #616197 Wed Jul 28 2021 11:40am
Agent_Trig
Yep, that's right.
I took the car in for wheel alignment as I always like to make sure things are straight and true. This is when the issue was found.
I spoke to the garage I bought the car from and they're covering the bill in full so all good Smile
Post #616198 Wed Jul 28 2021 11:43am
Post #616200 Wed Jul 28 2021 11:45am
Jjvd21
United States
Meyle HD Thumbs Up put them in both my D3 and D4 2020 SVR / R.I.P. 2019 SVR / 2016 D4 Landmark / 2005 D3 HSE
Post #616213 Thu Jul 29 2021 5:03am
