Home > Maintenance & Modifications > OBD Solar Charger |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1813 |
12.2 volts is low, should be around 12.6 volts fully charged
Wed Jul 21 2021 9:49pm |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 470 |
Do any of these use the OBD2 port.. ===========================================
Wed Jul 21 2021 9:54pm |
Direct route
Wed Jul 21 2021 10:10pm |
Sounds like this needs to be disconnected before starting the car,
Wed Jul 21 2021 10:23pm |
I would get the battery charged fully with a mains charger and then monitor the voltage after that.
Thu Jul 22 2021 8:46am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4907 |
Disconnect the solar and measure the pins on the car.
Thu Jul 22 2021 11:35am |
The instructions do say to disconnect while running the engine. 2023 P440e SE Dynamic on order -cancelled
Thu Jul 22 2021 12:04pm |
Thank you all for your advise,
Thu Jul 22 2021 4:58pm |
Good luck with it, probably only putting in less than 0.4 amp which will take a long , long time to get it fully charged. 2023 P440e SE Dynamic on order -cancelled
Thu Jul 22 2021 5:16pm |
OOOps didn't check that,
Thu Jul 22 2021 5:45pm |
As I said before, if you could get it fully charged with a decent charger then the panel would probably be fine for any small drain,etc. 2023 P440e SE Dynamic on order -cancelled
Thu Jul 22 2021 5:52pm |
1richard1 Member Since: 10 Sep 2019 Location: oldbury Posts: 178 |
Hi i use one of these and the car can be left about 6 weeks and starts fine i use the odb port easy to unplug when getting in and easy when parking up. |
Thu Jul 22 2021 7:28pm |
Hi 1richard1
Thu Jul 22 2021 9:54pm |
I thought my battery was going dud as the car was only used infrequentley i had to use my jump stater battery to get it started, and then have many faults come up whilst driving, then my van engine blew during covid whilst that was being rebuilt, i used the rangey everyday for work and all faults dissapeared, as all say here they like to be used and i have to agree, as my work can be 7 days a week i bought the solar charger and the beast always starts and no faults even when not used for weeks or even longer. |
Thu Jul 22 2021 10:12pm |
