![]() | Home > Maintenance & Modifications > OBD Solar Charger |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1875 ![]() ![]() |
12.2 volts is low, should be around 12.6 volts fully charged
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 474 ![]() ![]() |
Do any of these use the OBD2 port.. ===========================================
Direct route
Sounds like this needs to be disconnected before starting the car,
I would get the battery charged fully with a mains charger and then monitor the voltage after that.
Disconnect the solar and measure the pins on the car.
The instructions do say to disconnect while running the engine. 2023 P440e SE Dynamic on order -cancelled
Thank you all for your advise,
Good luck with it, probably only putting in less than 0.4 amp which will take a long , long time to get it fully charged. 2023 P440e SE Dynamic on order -cancelled
OOOps didn't check that,
As I said before, if you could get it fully charged with a decent charger then the panel would probably be fine for any small drain,etc. 2023 P440e SE Dynamic on order -cancelled
1richard1 Member Since: 10 Sep 2019 Location: oldbury Posts: 178 ![]() ![]() ![]() |
Hi i use one of these and the car can be left about 6 weeks and starts fine i use the odb port easy to unplug when getting in and easy when parking up. |
Hi 1richard1
I thought my battery was going dud as the car was only used infrequentley i had to use my jump stater battery to get it started, and then have many faults come up whilst driving, then my van engine blew during covid whilst that was being rebuilt, i used the rangey everyday for work and all faults dissapeared, as all say here they like to be used and i have to agree, as my work can be 7 days a week i bought the solar charger and the beast always starts and no faults even when not used for weeks or even longer. |
