Home > General > Oil sensor change - does the engine need to come out?
MallorcaNick
Spain 2011 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
Hi again,
2011 RRS 3.0 TDV6
I've just tried to get the oil level sensor changed but have been told that the engine needs to come out to do it, which is far too much time to justify changing it.
Do you know if they're right about this please? A previous mechanic, who I don't trust actually, had told me that it's a reasonably quick change.
Thanks again for any help......
Post #615707 Tue Jul 13 2021 11:58am
Iomegas
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi I’m sure it can be done with engine in and drop the sump but a cross member has to be removed to allow this.Im sure those more informed and wiser than myself will give you a more exact response.Hope you get sorted. Thumbs Up
Post #615711 Tue Jul 13 2021 1:59pm
Oldandconfused
From what I've read on here, no the engine doesn't have to come out, but the front diff does to access the sump. All in all a lot of labour for a cheap sensor replacement, and becoming more common.
There are a number of posts on here, have a search. I don't know if anyone posted costs though, which would probably be helpful for you.
Edit; bit of an old one but FYI
https://www.rrsport.co.uk/forum/topic38479...vel+sensor
Post #615712 Tue Jul 13 2021 2:42pm
