![]() | Home > General > Oil sensor change - does the engine need to come out? |
Iomegas Member Since: 15 Nov 2020 Location: Newcastle Upon Tyne Posts: 213 ![]() ![]() ![]() |
Hi I’m sure it can be done with engine in and drop the sump but a cross member has to be removed to allow this.Im sure those more informed and wiser than myself will give you a more exact response.Hope you get sorted. |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 ![]() ![]() ![]() |
From what I've read on here, no the engine doesn't have to come out, but the front diff does to access the sump. All in all a lot of labour for a cheap sensor replacement, and becoming more common.
