![]() | Home > General (L494) > Anyone Fitted the Auxiliary Belt Tensioner and a New Belt - |
2 RRS Member Since: 04 Sep 2016 Location: Shropshire Posts: 156 ![]() ![]() ![]() |
That's a bummer, fix one thing for another to crop up, that LR's for you!
It'll be on it's bump stops (makes for an interesting drive) which is the default position if an there is an error in the suspension system. Can you hear the compressor running, did you put it all back ok after flipping it over to disconnect the battery?
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 590 ![]() ![]() |
Hi , I just lifted the small piece of carpet and disconnected the earth but it was dropping before I swapped the alternator over |
A height sensor could cause it as the suspension will try to self level firstly across axles and then front to rear and if one corner is giving bad data then it'll just keep levelling down all the way with ultimately the front then dropping to match the rear in it's safety position (bump stops). Pop the wheel off and check the height sensor, pry the plastic bar off and make sure it moves freely and the bar isn't bent etc. Just be aware if you remove the height sensor from it's mount and re-install it will need to be calibrated as the tolerances are very tight.
The car dropped from standard height overnight right down, started tonight and put her up into standard height and the back comes up and then the front, then into off road height and the front pops up first and eventually the rear comes up ?
It definitely sounds like it's constantly levelling overnight due to a bad sensor. If you can, leave a door open as that will stop the suspension moving and then see what happens.
Okay will try this at the weekend and see what happens .
I don't think the front/rear lifting one after another is a problem as mine does that to a degree. Ideally you need to get full digit codes to point you in the right direction, do you know what the exact codes were? Still worth looking at the height sensor as I said before.
OSR ride height sensor changed today and seems okay so far |
