Home > General (L494) > Anyone Fitted the Auxiliary Belt Tensioner and a New Belt -
Red Arrow
My tensioner has started to be a bit noisy so have a genuine one along with a new belt to fit .
Is this an easy job ? Thumbs Up
3.0 DSL
Post #615024 Mon Jun 21 2021 8:51pm
2 RRS
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Bourneville
Easy job if the vehicle is not a dynamic model, if it is then the ARC pump needs to be dropped off it's mounting to pass the belt around it. 20 mins for std vehicle, double that for dynamic.
Post #615045 Tue Jun 22 2021 8:06am
Red Arrow
Thanks , Its a Dynamic Big Cry
Post #615061 Tue Jun 22 2021 8:15pm
Red Arrow
Whats involved in fitting just the tensioner ?
Post #615166 Fri Jun 25 2021 7:08pm
2 RRS
5 minute job. release the belt with a 3/8 ratchet extension/bar and then a 15mm bolt holds the tensioner in place. My belt has done 204K and is still fine so I'd imagine you just need to change the tensioner (mine went noisy about 10K ago). Are you sure it's the tensioner that's noisy and not the alternator? Maybe stick a bar against the alternator and tensioner and have a listen.
Post #615167 Fri Jun 25 2021 7:35pm
Red Arrow
Tensioner fitted earlier and guess what , you were spot on Thumbs Up
The alternator is humped , very noisy
What sort of job is the alternator to change ?
Thanks Big Cry
Post #615188 Sat Jun 26 2021 7:13pm
2 RRS
Thought it might have been.... Not too bad a job, all from engine bay, remove belt and tensioner (gives you a bit more room), 3 bolts hold the alternator (2 towards the front and one at the rear, pull it forward and by touchy feel undo the main 12v battery feed cable and one clip in cable at the rear of the alternator. Obviously make sure you disconnect main battery in boot first, otherwise you'll have a firework show on your hands! Prob 60-90 mins first time doing one.
You may find the noise is from the clutch on the alternator shaft as opposed to the alternator bearings, but in all fairness I'd change the whole unit as you'll be back there again otherwise in the future!
Genuine recon is about £450 and new unit (which strangely is an exchange item) is over £800. Both have 2 years warranty. Lots of cheap second hand ones on EBay, but again how long will it last???
Alternative is get yours off and take it to be refurbished.
Hope this helps
Post #615190 Sat Jun 26 2021 7:29pm
Red Arrow
Thanks a lot for your help its much appreciated Thumbs Up
Post #615191 Sat Jun 26 2021 8:05pm
Red Arrow
Hope this helps
Thanks it appears two are listed for it , Can anyone help with the OE number for the alternator - 2014 hse dynamic 3.0 dsl
Post #615281 Tue Jun 29 2021 9:08pm
2 RRS
LR part No. is LR088850 (recon, outright), part No. on unit is CPLA-10300-BD
180 Amp rated 2014/15 3.0L Dynamic with stop start
Post #615288 Wed Jun 30 2021 11:40am
Red Arrow
Brilliant thanks again for your help
Picked a brand new OE Denso unit up for £90 Thumbs Up
Post #615330 Thu Jul 01 2021 12:21am
2 RRS
Result!
Post #615369 Fri Jul 02 2021 8:43am
Red Arrow
Moved the car over on the driveway when I got back home tonight , ready to fit the alternator tomorrow and its showing suspension fault and adaptive dynamics fault on the dashboard Big Cry
Car looks as if it is sitting lower . Could this be related to the alternator issue ?
Post #615386 Fri Jul 02 2021 8:14pm
2 RRS
Maybe low battery if the aux belt is removed? I'd sort the alternator and then take another look.
Post #615410 Sat Jul 03 2021 2:16pm
Red Arrow
Alternator fitted and fine Thumbs Up
Suspension faults still showing and I also noticed the car has dropped very low after being parked at normal ride height for around 20 mins Big Cry
Post #615418 Sat Jul 03 2021 4:10pm
