Home > In Car Electronics > sat nav radio blue tooth and voice activation not working
grimreaper
Help required please guys sat nav packed in halfway through a trip radio cd phone and active voice not working I understand that if the blue tooth unit fails it knocks out everything else I have found the blue tooth unit and if that has failed then I will change it bus firstly is there a work around to get everything else working is there a check or test that will tell me it is the blue tooth unit before I go and buy another unit car is 2010 range rover sport hse thanks in advance
Mark.
Post #615429 Sun Jul 04 2021 12:14pm
Yeah you buy this to bypass the BT or amp or display
https://www.ebay.co.uk/itm/153598740005
I think there is a more common fault with your age car
Worth search on here
Post #615434 Sun Jul 04 2021 2:49pm
grimreaper
Thanks Andy K will sort out battery and order the item hopefully that will sort it until i replace the BT unit
Mark.
Post #615438 Sun Jul 04 2021 3:52pm
grimreaper
New Battery fitted all under seat boxes un pluged then re pluged still no sat nav, radio or rev camera no phone and no voice activation but screen lights up so did the next suggestion Hard Reset all still the same any more idea anyone can pass on otherwise it will cost an arm and a leg to run diagnostics for this TIA
Mark.
Post #615585 Fri Jul 09 2021 10:48am
