Home > Maintenance & Modifications > The demise of my problems Tdv8 |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 948 |
I think in all honesty a lot of people regard the TDV8 as one of the better landrover diesels,, biggest known problem being the turbo's as you found out,,, but if lookedafter can last a good while. A bit unfair saying youhave no faith in that engine as no matter what you have you can still have problems. Sometime some of us are just a little more fortunate than others,,,, or unfortunate depending on which way you look at it. 2010 RRS, TDV8
Sat Jul 03 2021 10:47am |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1540 |
How many miles had you done #Jimbo? Robin
Sat Jul 03 2021 11:48am |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
You don’t say which mechanic, but if at all possible get Steve at T&S Norman have an assessment of it. Equally he may be able to help , certainly worth a phone call. 2006 2.7 TDV6 HSE in Cairns Blue. |
Sat Jul 03 2021 7:57pm |
#jimbo Member Since: 25 Jun 2019 Location: somerset Posts: 6 |
Less than a year since the turbos and probably not even a thousand miles. Always left to idle at least 30 sec before shut down. |
Mon Jul 05 2021 3:23pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8994 |
How many miles on the engine in total?
Mon Jul 05 2021 3:30pm |
Thanks for the recommendation. |
Mon Jul 05 2021 3:31pm |
It wasn't serviced just before it failed, was it? Incorrectly fitting the oil filter is pretty terminal. 2012 SDV6 - it's missing a couple of cylinders
Mon Jul 05 2021 3:37pm |
No wasn't touched since turbos and gearbox module. |
Mon Jul 05 2021 4:01pm |
Jamesc4228 Member Since: 10 Jul 2021 Location: Lincoln Posts: 1 |
Hi I am new to this forum so apologies if this isn’t allowed , but I have a 3.6 TDV8 engine in my workshop that I bought over a year ago for a customer who decided at the last minute to not have the work done . Are you anywhere near Lincoln ? It’s about time I got it out of my way so it might help you out |
Sat Jul 10 2021 10:48pm |
90000 |
Fri Jul 23 2021 12:06pm |
No im in somerset. How much is it and is there any history with the engine? |
Fri Jul 23 2021 12:10pm |
